Hi all,
We're in the process of installing a (15'x34') fiberglass pool. Half way through the dig everything ground to a halt. The spring water table on our property is sitting around 48-50" depth while the pool depth is 3'6"-6'6". It has been fairly wet lately with snow and rain. We're not clear yet how much of this is purely water table vs run off or ground water from neighbouring properties which are slightly higher than ours.
The installer met with us and their recommendations were:
They do install a pool sump/dewatering well/groundwater shaft, but they don't seem to think that's adequate but haven't articulated why (unless they're just trying to get out of their warranty). What's also not clear is how low the summer water table is expected to be.
Today we pumped it out (still some remained) and we're to send a photo to them tomorrow morning to see how much returned (like a well recovery rate). But given that it's been so wet, and is expected to rain for the next few days this won't be a good measure.
If we overdig and lay crushstone underneath, install the pool sump and a hydrostatic valve should that be sufficient to mitigate the risk of popping the pool in the wet season?
Thanks in advance for any input!
Cheers,
Mike
Below is a photo of the water that has collected since Thursday (photo taken on Monday).
- to raise the grade around the pool 1'6"
- which would require a french drain around the pool to ensure there are no water issues with the house foundation (walkout basement), and
- leave us with 2 steps to get up to the concrete decking, or
- change the pool to a shallower pool (~5` depth),
- otherwise they won't warrant the install.
Cheers,
Mike
