Opened the pool yesterday. I can not recall it ever being so stinky before. It is not unusual to have lots of worms, etc. on the bottom that I sweep up before putting the DE grids in, but this time something seemed very different. What was coming up was something I don't recall seeing before - can't help but wonder if at some point a few animals got in there and decomposed over the winter. Opening the pool so far has been kind of like reading Stephen King.
Strangely, though, I had the pool partially uncovered every few months during the late fall and winter to check the water chemistry, and didn't notice any odor. Actually, the water looked pretty good also nearly every time. Now, though, having started filtering today, I've already gone through 3 charges of DE in the space of like 4 hours. Typically, each load of DE results in increasingly longer filter cycles, but so far that is not the case. Right above the return lines, there is a brown swirling area that is quite unsightly - not sure if this is the result of adding algicide or if I'm still seeing the results of whatever decayed during the off season. I've gone through at least 20 lbs of DE already and, if this continues, will exhaust my only 25 lb. bag....told my pool store that I want at least 50 lbs. more. Looks like this could be a L O N G season. A retirement community that has a pool I could swim in but not have to maintain is looking better and better!
Any thoughts on how I might better clean up my version of the dismal swamp??
