An Introduction to My Pool - Old Plaster - Old Pool - Black Algae !
AH, Thought you were out of startup. Then stick with 1.5-3 for your startup FC. Sorry.
@PoolStored @ajw22
An odd phenomena has occured. I tested this morning and my Chlorine is reading 12 ppm after a pretty heavy rain last night. I brought chlorine from 1 to 3 ppm yesterday and I added the maintenance dose of the jack's magic blue yesterday could this have something to do with it?
Test again, wiping the tip with a paper towel between drops.
I doubt they are brass. I don't think there is a pool fitting maker that would use brass. Bronze is more likely.
Salt with brass can cause de-zincification. However, every form of chlorination ends up adding salt. My pool was 2000ppm when I installed my SWG. Any pool chlorine or salt is a salt pool.
More likely they are bronze. Bronze and salt is not an issue.
I would not worry about it.
@PoolStored Thanks, the pool is probably 50 years old.
