Ammonia
Welcome to the forum!
How are you testing your pool water chemistry? Please post a complete set of results from your own test kit.
Not likely the pool has ammonia in it as there is CYA (unless you just added a bunch) and the pH is high.
I suggest you read through Pool Care Basics - Trouble Free Pool and even look at a few of our videos TFP-TV - Trouble Free Pool
Thanks! Tired of wasting money on our pool… excited to get a better handle on things.
I tested two different ways - once with my Taylor kit and then at the pool store. My CYA wasn’t as high in my kit as at the store… these are the pool store results
I have the 2005, but also have FAS-DPD to test chlorine. Here’s what I got there.
Build Type: Plaster
Volume: 12000 gallons
Chemistry: Chlorine
Latest Test Result Summary:
FC: 2.0 (12 minutes ago)
pH: 7.8 (12 minutes ago)
TA: 90 (12 minutes ago)
CH: 340 (12 minutes ago)
CYA: 40 (12 minutes ago)
TEMPERATURE: 80° (12 minutes ago)
CSI: 0.24 (12 minutes ago)
No visible algae
Algae is microscopic. By the time you can see it, it's way too late.
The red flags such as unexplained FC loss are your warning sign before its too late with a swamp.
Overnight Chlorine Loss Test
If you can prove it's not algae, that buys us time to fiddle with the rest of it Marty suggested above.
Reactions: logz83
