- Jun 26, 2015
- 83
- Vinyl
- Intex Krystal Clear
So I haven't measured my pool for probably a month. I base it off of "look/clarity" of the water. If it looks a little cloudy, I check to see if my pump ran (I have sense which measures my power in and out.) So I can check that app as it has found my pump, to see if and when it has ran.
Anyway, I'll run the pump (hooked to a SWG) and check next day. And so far its always cleared up.
Back in May/June I measured everyday, working out to once a week watching what the levels were doing. Cl was always 3-5 range and PH stayed 6.8-7.2
Now its been hot, and I have been a whimp with the heat (no I don't even want to stand out there and run a quick test lol)
So a Month later and my daughter and grandson came to swim.. I decided I better check them levels. Cl still the same (SWG doing its job YAY) PH bumped up to 7.8.. Water still pretty clear, and there is leaves and debris in the bottom that I need to VAC. See my temp complaint lol.
So Am I lucky, or have I dialed my particular pool and its usage (and my 14 yr old and her friends use the Crud out of it) in that I really can get away with looks and occasional checks (yes I need to get back to at least once a week)
And yes, its a slight pat myself on the back post.. The family just doesn't understand how awesome this is. hahahah
Thanks for the input
