I figured I would just update this thread to anyone who finds it
The pump has been great, I have not noticed any issues and flow is fantastic. The filter has also done well, but as suggested it does need more frequent cleanings. If the pool is really, really dirty I may need to clean once a week, however I can usually get away with every 3-4 weeks with no problem. This is also with my terrible pool plaster which I'm sure clogs it up a fair bit
If it were to do things again, I would probably get a bigger filter. At the time I had no idea the results I was going to get, so I was hesitant to spend buckets of money on a bigger filter. I will probably keep this filter for a while until I really get an idea of what I want, and then upgrade to a larger filter
The bubbles are greatly reduced now too, they are minimal enough I don't worry about it. I also lose much less water now, I suspect there was a leak in some of the plumbing or the selector valve which caused water to drain when it shouldn't have been
