Hello I have the TF-100 Test Kit. Purchased it around a year ago. When I tested my chlorine with the small daily kit it showed a 2 and the more extensive kit with the R-0870 (powder looks like moisture got in) indicates the same. So I had taken my water to two different pool stores for analysis who both had the same results:
FC 10
PH 7.8
Alkalinity 175
Hardness 400
CYA 100
They said my chlorine is too high, wait 24 hours retest and the Alkalinity is high to add 4 cups of MA but split between 3 treatments.
First of all the pool company informed my that the test kits only have a shelf life of 6 months? Is this correct?
Also doesn't the Alkalinity/PH go up when the Chlorine is high? and should go down as Chlorine lowers?
Thanks for any input.
FC 10
PH 7.8
Alkalinity 175
Hardness 400
CYA 100
