Brandy Spears
2
Carrollton, Georgia
So I have a Taylor test kit and I also take my water for testing at our local pool store. I have my chlorinator set at 75% and at times turn on my super chlorinator because we have very little FC. I notice on my tanning ledge and steps that I have the little black spots of algae. They are not big and the don't cover the whole surface. So I do but some algaecide in and extra chlorine tabs. Anyone have suggestions to help? My pool gets tons of sun all day long.
Algaecide shouldn’t be used in normal pool care and is only a preventative measure - doesn’t do jack squat once you have algae.
If you’re using chlorine tabs, realize that every chlorine tab adds chlorine + CYA. The chlorine gets used, the CYA sticks around, building up to a point where the chlorine can no longer work.
Test Kits Compared
You need a proper test kit and you need to stop going to the pool store. They’ll only serve to confuse the issue more, and lighten your wallet. If you have a proper test kit, a SLAM Process can fix the issue, once and for all. But the tab chlorinator got you into the mess and you’ll need to get rid of it, and the tabs.
