Will do. Thank you! Retook chlorine and acid levels.That needs to be raised. I assume your fill water is fairly low in CH. Hetch Hetchy water?
Get some calcium chloride. Get CH to 250 ppm.
FC-0.5
CC-0
ph-7.8
Is there a point to chlorine block test if you do drop test?
Realized I didnt add enough acid (forgot to enter TA in pool math)
