Hello! I have crystal clear water and my levels are all within range (after fighting to lower my CYA all of last year; I had been using chlorine pucks but thanks to TFP once I started using liquid chlorine, most of my problems disappeared). My concern is this: I can vacuum and within an hour or two, I have dirt along the seams of the pool again. At least I'm almost positive it's dirt...but could I STILL be fighting algae? We slammed the pool last summer and opened up this spring to crystal clear water (and great numbers) but lots of dirt and a few leaves on the ground, but once we brushed and vacuumed a few times, it's looked good. However, I continue to get a buildup along the seams and I am wondering if some fine dirt or sand is getting in through the filter. Here are my numbers from Sunday afternoon:
FC 2.5
CC 0.5
pH 7.5
TA 100
CH 150
CYA 30
It's just starting to warm up here and I'll probably try to keep the FC around 4 if I can, but I'm open to input. But my huge hope is that you can solve my need to vacuum every couple hours! Thank you!
FC 2.5
CC 0.5
pH 7.5
TA 100
CH 150
CYA 30
