Algae keeps coming back
rowiac
76
Tehama County, CA
Test for FC each time before you add chlorine and then add the amount that PoolMath tells you to get to your SLAM FC level (SLAM FC=12 if your CYA=30). It will seem like you are adding a whole lot of chlorine, but keep at it. It's likely to take several days, but the amount of chlorine use will go down as you progress through the SLAM.
mknauss
30,934
Laughlin, NV
You can safely swim in a pool as long as the FC is above the minimum and at or below SLAM level based on your CYA. You must also be able to see the bottom of the pool in the deep end of the pool.
jandersen13
127
Grand Rapids MI
Ok so I raised the FC to 16ppm last night. This morning it was at 11ppm. Added more and around 1pm my wife checked and it was about 8ppm. She added more. I checked at 5:30pm and it was 8ppm. I added more chlorine.
My question here is that there is still algae growing on the bottom. I brush and there’s a small amount in the deep end floors. Am I doing this right? Still a slight tint of green.
IceShadow
2,177
Milwaukee, WI
That sure doesn't look like it's helping! I'd get an old toothbrush and some diluted bleach and go to town on it.
EDIT: Or a power washer followed by a rinse with diluted bleach
jandersen13
127
Grand Rapids MI
Thanks! Will do. I’ve kept it out until I get it washed properly.
Just a check in. FC lost 2-3ppm last night. Held at 8ppm from this morning until noon today. I just added more. Still a small amount of algae as I brush the deep end.
My question is, will I still see that light algae for a few days? Just want to know what to expect. I thought that would be gone by now. Pool looks great other than that.
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
34,047
I am just now skimming this thread and, unless I overlooked it, you need to add 4 more lbs of CYA (stabilizer). That will get you to 30 ppm which is where you should be for the SLAM. You really didn't add enough to do a valid test.
jandersen13
127
Grand Rapids MI
I’ve been maintaining the chlorine pretty well the past few days. The water looks pretty clear and good. I’ve been brushing and running the robot vacuum. But I still see a small line of algae in a few spots and then when I brush the bottom it kicks up a small amount of what I think is algae as well. What am I doing wrong here? Or will this last for days?
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
34,047
It will last until you have eradicated all the algae in your pool and you have brushed it up into the water so your filter can pick it up. Continue the SLAM.
jandersen13
127
Grand Rapids MI
Still continuing here. My main drain does not work so I just work from 2 skimmers. Do you think this will take a bit longer to get the dead algae out because of that? Also would dead algae not clump but just remain on the bottom when I brush it and look like dust as I brush? Or is that active algae. Trying to understand if I have active algae or just dead algae I need to get out.
