- Oct 25, 2015
- 5,829
- Plaster
- CircuPool RJ-60 Plus
dj,
Based on everything I see in your reports I would expect your -4 FC is unlikely to be correct. That said it's also concerning since you've tested a LOT and it would be hard to make an error that large even though you are counting a LOT of drops. You've worked so hard to get where you are I'd perform an OCLT test tonight. If it passes I'd let the FC drift down and do another OCLT test in a couple of days. OCLT test just does not ever fail when performed meticulously.
I hope this confirms you've transitioned to TFP pool bliss and permanent sparkling pool!
Good luck!
Chris
Good luck!
Chris
