- Jun 24, 2021
- 15,885
- Vinyl
- CircuPool RJ-60 Plus
Looks like oh is higher than 8.2.Add your test kit to your signature - it really is part of your equipment.
Post a full set of current test results from your TF100 test kit.
Don't bother posting pool store results - they are worthless. Trust your TF100 test results.
Post pictures of your equipment pad from a few different angles so we can see what you have.
You have a cartridge filter. Clean your cartridges. Note clean pressure. When clean pressure rises 25%, then clean the cartridges again. Say clean pressure is 20, clean when you hit 25.Have a pentair filter. I’m trying to figure out how to backwash as I don’t see that as an option
I did the test again with the sun behind me and it was closer to 80. I did the diluted test and it was about 60.You have a cartridge filter. Clean your cartridges. Note clean pressure. When clean pressure rises 25%, then clean the cartridges again. Say clean pressure is 20, clean when you hit 25.
You may be cleaning cartridges often.
pH test is invalid when FC >10. You only need to test and replace FC during SLAM.
With a CYA of 90, you should do diluted test...#8 on this page...Link-->CYA - Cyanuric Acid Test
Should I replace 25% before SLAM?80 would be correct. CYA is turbidity test and is reliant on the light. Slam target is 32.
It is more difficult to slam with CYA above 60, but can be done, and will take a fair amount of chlorine.
You might be wise to replace 25%+ of your pool water. Read no-drain water exchange here:
Draining - Further Reading
www.troublefreepool.com
This is my current level. Does it neee to be cleaned now and then get another reading?You have a cartridge filter. Clean your cartridges. Note clean pressure. When clean pressure rises 25%, then clean the cartridges again. Say clean pressure is 20, clean when you hit 25.
I have 2 socket sets all the way up to 3/4" and didn't want to buy another just for the 7/8"....Although you can never have too many tools..Harbor Freight can provide you with a real man's tool set so you don't have to buy a one-off standard socket that we all have in our tool boxes already.
