- Mar 5, 2020
- 3,107
- Plaster
- Astral Viron V35
I am following your Forum for quite a while now, but this is actually my first post. After constantly having algae problems when following standard advice on FC levels, I was very happy to learn about TFP's approach in adjusting the FC-level to the CYA-level. Having a physics background, I quite enjoyed diving into the deep end and going through some of the papers that Richard was referring to. After SLAMming, no more algae by sticking to the recommended FC-level.
Now that we are heading into winter here in Australia, the pool is cooling down. Melbourne is at the cool end of Australia. We don't get snow, but water temperatures will go down to 5-7°C (41-45°F). The pool is now at about 11°C (42°F) and I noticed some algae returning. Then I thought about the temperature dependency of the CYA / Cl equilibrium and turned the temperature dependency in Richard's pool equations spreadsheet on, and calculated the HOCl concentration at different temperatures.
At FC=4ppm, CYA=60ppm and pH=7.7, we get HOCl=0.025ppm at 25°C(77°K). At 20°C (68°F) this goes down to 0.013ppm, at 10°C (50°F) we are at 0.0032ppm, and at 5°C (41°F) we reach 0.0015ppm. This is a massive drop and I am wondering if I should increase the FC-levels to keep HOCl constant at about 0.025ppm. This would require FC=18ppm at 10°C (50°F) and FC=23ppm at 5°C (41°F).
This would be quite a high FC-level to be maintained through the peak of winter. The standard advice usually is that high FC will damage the pool (I have a plaster pool). You hear reasons like high FC will result in low pH. I don't really believe in this, I am running an SWG, sometimes topping up with Cal-Hypo, both increase pH rather than decrease. I am watching the CSI and keep the pH now more towards 7.8 to compensate for the colder temperatures, so plaster wise I should be OK, I think. But what about other equipment like pump, filter, pool cleaner, hoses and pipes? And are there other effects on plaster by high FC, rather than just CSI effects? I am not really concerned about swimmer safety, the pool is not being used over winter anyway (apart from a few ducks from time to time - cute visitors, but very messy).
I guess, step 1 is to not fight the CYA decrease over the winter season with increasing rainfalls diluting the water. At CYA=30ppm and pH=7.7, we'd only need about FC=12ppm to maintain HOCL=0.025ppm at 5°C (41°F), which sounds a lot more manageable.
Or I could add an algaecide. I did that last year before I learned about adjusting FC to CYA, but I don't really like the smell these algaecides are adding to the pool, so I'd rather go without them.
What are your thoughts, does that make sense to maintain very high FC over winter, keeping HOCl constant according to Richard's spreadsheet? You would think that algae gets less active in winter. But at least now (at water temperatures around 10°C (50°F)), algae seems to be happy to grow at FC-levels that were fine above 20°C (68°F).
What are your experiences with algae at lower temperatures?
