We've been struggling with keeping backswimmers out of our pool. Everything we read says algae leads to boatman which lead to backswimmers. We are very new pool owners (installed late August) and had been taking advice from the pool store guys until earlier this week when we found this site and forum. We've been reading constantly and feel like we have a decent grasp on most of the basics but still very unsure we'll be able to correct our issue. Although we have never seen visible algae, we are assuming it's there because of the constant infestations of boatman and backswimmers. We are currently performing Overnight Chlorine Loss Test but the plan is to start a SLAM tomorrow regardless of the result. But when reading on the SLAM process, our current CYA level of 20 would require us to elevate our FC to 10ppm. We just started monitoring our CYA level as our pool store guy originally told us our chlorine pucks had all the stabilizer we would need. Obviously not true because we had been at 0ppm but now have been able to raise to 20 with stabilizer. So we're getting there. Getting back to SLAMing the algae, based on our CYA level of 20, our recommended SLAM FC level is 10ppm. The concerning part about this is that we double shocked (pool store shock) 3 nights ago and our FC test tonight was 10.5. So isn't this the equivalent of SLAMing based on our low CYA level? And if we've technically been unknowingly SLAMing for 3 days now, shouldn't we be seeing some results with the algae/boatman/backswimmers? Or is our CYA just too low and the corresponding FC recommendation just not enough to kill the algae? If so, is there a standard minimum FC level needed to kill algae regardless of CYA? Obviously our heads are spinning and any input is greatly appreciated
