We replaced our liner this spring and I got the parameters of the pool set up pretty well after a city water fill. Recently, algae has reared its ugly head and I found that I was not running the salt cell enough to keep the chlorine up. I threw in stabilized shock to get the chlorine back up fast and started running the pump more. It was somewhat good for a week or so, but now I'm getting algae again and the water is cloudy. I tried dry clarifier in the skimmer, which has worked in the past but no luck. After carefully adjusting the CYA after the fill, I'm sad to see it's up to 90 after adding the stabilized shock. I've always had an issue with high CYA.
Here are today's readings (all done with Taylor test kits):
FC: 10.2 ppm. This is more than a week after adding the shock, so this level is being maintained by the Circupool RJ45 plus salt cell.
Combined chlorine: 0.4 ppm or less
CYA: 90
Alkalinity: 70 ppm
pH: 7.2
Salt: 3500 ppm
It got dark before I could check calcium, but that was in the normal range last time I checked and I've not added any.
Suggestions?
CYA: 90
Alkalinity: 70 ppm
pH: 7.2
Salt: 3500 ppm
Suggestions?
