And I mentioned before.....I'm definitely due for a filter clean which I plan on doing this Sunday. Any chance this could be related....as in, just not enough water pressure to push the air out?
How would that happen without an actual venturi and where would it be drawing in air if the system is sealed?Jamesw said:You're tapping into the return below ground and probably getting some venturi effect.
I don't understand this either because the pressure at the booster will be identical if you plumb it either way (except for dynamic head loss). Remember that static head loss works both ways. When water drops in elevation, it gains pressure and when it rises in elevation, it loses pressure. Net net, there is no static head loss just because you plumb the feed pipe under ground.The way it's plumbed in not pushing water into the pump.
But the pressure is higher the lower you go so I don't understand this comment. I as said before, the static head loss offsets from high to low back to high elevation so there is no difference where you tap the pipe. The pressure into the booster will be about the same.. Since the line is low, the pressure might not be enough to push water higher than the top of top of the highest part of the Polaris pressure hose.
Any tee or any fitting will lower the pressure within the fitting due to head loss. These are well known and predictable. That is not the same as a venturi. This is a venturi:You won't get a full venturi, the return water is flowing perpendicular to the Polaris suction line. That will lower the pressure somewhat.
If there is water pressure on the inlet of the booster, as we have concluded there is through multiple tests, this pressure will push out any air. Unless of course something is significantly restricting flow.JamesW said:However, if air gets in the line, the booster can't clear the air because it's not self priming.
OP stated earlier there is no air in the pump basket or even the filter. But I do suspect an air leak somewhere.Maybe a suction side air leak is new.
If there is good pressure into the booster, there should be some water coming out of the wall fitting even if there is a 90 % clog.If there is water pressure on the inlet of the booster, as we have concluded there is through multiple tests, this pressure will push out any air. Unless of course something is significantly restricting flow.
Flyguppy,
Did you ever fix this problem? Could be where the air is coming from.
Normal for this much DE in bottom of filter?
Ok, how long have you been at this property?
Has this been an issue since you moved in?
The suction going directly into the ground is odd. It's almost always Teed in above ground.
I really think that there is an issue with how it's plumbed or a significant blockage on the suction side. Maybe dig down to see what's down there.
Have you tried removing the wall fittings (all of them) to see if the flow improves out of that pipe?A possibility for the restriction could be the wall fitting. I think there is a restriction placed in that fitting that can easily get blocked:
Might be worthwhile disassembly the entire assembly and cleaning it. And flushing out the line without the fitting.
