When my pool pump starts (at 7:00am), there are lots of bubbles gushing out of the returns for about a minute before settling down. After the pump turns off (even hours later), you can hear a "glug, glug, glug" coming from the pool filter. It sounds like there is water being emptied from a hole in its side (though I've found no water leakage from the filter). BTW - the filter is only a few years old.
I am assuming I am getting air into the system on the suction side. So, I first removed my leaf canister (to take it out of the equation), but the issue has not changed. I have an old Hayward pump that was here when I bought the house 2 years ago, so it may be due for an o-ring change. I just purchased the kit (
Hayward SPXHKIT2 Quick Pump Repair Replacement Kit for Hayward Super II Pool and Spa Pumps), which includes: strainer cover O-ring, housing gasket, seal assembly, diffuser gasket and Jack's lube. I also ordered a new lid (since my clear lid has become opaque due to old age).
Changing the pump lid and it's o-ring will be my next attempt to fix the issue. Then I need to look at what the other parts are for and see if they could be playing a role if it still sucking air somewhere.
Does this sound like a reasonable start to addressing my problem? Am I missing something I could check for before my pump parts show up in a week?
Thanks!
Thanks!
