Hello all, I have 2 quetions. I'm sure this is an easy fix but I don't want to break anything. The air relief valve on my Pentair Clean and Clear 200 filter is pointed in the wrong directions. It points directly at the heater vs out into the open area. So everytime I release air it soaks into the heater. I tried to rotate the lid but then it does not line up with the internal valve. How do I point this in the correct position?
The second question is why would my pressure gage still read a normal PSI 12 when it was full of debris. I put off checking the filter because the pressure was good and newly installed. However we have had a lot of debris in the pool so I thought I should double check. It was full of the small yellow droppings from the Palo Verde and Mesquite tree's. I washed and put everything back togehter. No change in the filter pressure when I started back up? Thanks in advance. Gina
