I had a diamondbrite installed last October on budget (myself and couple stucco guys). Everything went fine except one genius attending the paddle mixer got destructed and let the diamonbrite settle inside the mixer towards the very end. I had to refocus on saving the paddle-mixer and let the other two continue mixing by hand-held drill and finishing up in the hot-tub area. There was a 2sq/ft area on the seat that was discolored from the beginning (lighter color than the rest of diamondbrite) - I am guessing it was a thicker mix or mix that was almost dry when it was put on and now I noticed that there is a air or water "pocket" under that area when I step on it (I feel it moving).
What should I do? wait until it breaks up or should I immediately empty the pool past that area, break off the loose gunite and put a fresh one just in that area? Again, this is just the 2sq/ft area on top of a seating area in hot=tube section but the rest of the pool looks fantastic. Thank you.
