We have a lot of air in the pump basket and returns, I tried lubing up the gasket with silicone based lube. We also lubed up the o-rings and made sure they were in correctly. Skimmers are running fine, no vortex, water level is up a little higher than normal as part of my troubleshooting and that didn’t change anything either.
When it rains heavy then the air goes away completely. If I shut off the far skimmer valve then the bubbles mostly go away, when I shut off the main drain as well and just leave the other skimmer open then the bubbles disappear completely.
1. What can I replace the valves with that will fit in the tight space?
2. When replacing the valve do I need to do anything special besides shut off the pump/filter and open the air bleed? (equipment pad is higher than the level of the pool)
3. If I open the valve the air swoosh’s in, does that mean the leak could be prior to the valve or can the valves suck in air when open?
4. If the leak was underground would it suck in dirt as well? (I don’t see any)
Our next step is #1 above unless the experts here think we should start elsewhere. The pool was built in late fall of 2015 and has always had the air leak. The pool builder was told but never fixed it.
