Hi all,
I recently posted about our 1 year old pool being built with one skimmer and no suction/vac line in skimmer causing it to have poor performance. Fast forward pool co agreed to add the suction line to the Venturi style skimmer and it immediately started pulling leaves in like a champ. However, I’m noticing air and bubbles I did not notice before in my pump basket AND we have water pooling behind the skimmer. The air in pump decreases on higher speeds but some is still there. It returns at lower speeds over night. The deck is not repaired yet. Builder saying this is all normal and that it’s a wet spot /low spot in our ground.
Our pool is losing just over 1/4” per day and the water behind skimmer is rising, not evaporating or draining. Before they cover up this repair with dirt and concrete I’m thinking it needs to be inspected. Of note is we recently had the pool replastered. Our pool was finished in Oct 2020 and it’s been problem after problem so I have been extra watchful.
We are in the Houston area. Clay soil.
Thank you!
Thank you!
