I have an indoor pool, 16’ by 26’. All of the piping is accessible from the crawl space under the floor. When it was installed 4 plus years ago, the plumbers put a Jandy 3-way valve under the floor, directly above the main drain. That worked fine but any time I wanted to adjust the valve, I had to go down there and adjust it. The pump is about 12 feet behind the valve and is another 5 feet to the right of this valve. So I decided to remove the Jandy and run separate lines from the main drain and the skimmer up to just before the pump topside. Now I can adjust the skimmer-main drain easily. I did this about 1 year ago. The problem I want to address is that I now get a considerable amount of air coming from my return lines in the pool. I have tried to take a photo of this but it really doesn’t show. I have no idea where this air is coming from. I have no leaks whatsoever in to crawl space. But I am wondering if this air in the system will damage my pump? It’s a Pentair variable speed model that works very well. I am also wondering if I should put two check valves just before the pump to prevent air from leaking back when the pump isn’t running? Any advice would be greatly appreciated. BTW, my old username was Bwdonohues58.
