I am getting air in my filter and not sure where it's coming from. It is a fairly small amount. Usually clears when I open the bleeder valve in about 5-10 seconds. Then, I close the bleeder valve and air starts building up in the filter again. I do also have a little air in the pump lid, but the filter seems worse. What is the most likely culprit... air leak in suction line... o-ring on the filter lid (I've ordered a new one)... issue with multi-port valve... other issues?
