Air bubbles in closest two return lines
Bketchum5
Active member
Jun 17, 2018
38
edmond,OK
Pentair Intellichlor IC-40
I’ve got air bubbles, a lot, coming out of my two closest return lines and a small amount of air bubbles coming out of my spa return lines. I’ve checked everything. Skimmer basket doesn’t have any visible cracks. Checked Strainer Basket looks fine, replaced gasket, unions connecting pump to return lines. No visible leaks of water upon startup. I’ve had small amounts of air before but this is pretty extreme. I’ve not checked to see if I have any loss of pressure or cracked pipes since the ice storm (im in Oklahoma) but I have not seen a significant amount of water loss or any wet spots in yard. My pressure gauge is at about 18 psi, usually sits at 20. Checked drain plugs. No leaks and replaced gaskets. Should I have a professional check for any air leaks? I don’t know what else to chekc other than to clean filters and see if that will increase pressure.
cowboycasey
5,805
Southern OK
Is there any air in your pump basket/lid?
when you purge air out of your filter does it stay out? purge the air till only water comes out, then wait 10 minutes and do it again.. does air come out again?
Bketchum5
Active member
Jun 17, 2018
38
edmond,OK
Yes. There is air and turbulent bubbles. Not like the streaming flow I’m used to that looks like there’s no water when it’s running good.
yes air comes out of pressure gauge but no the bubbles don’t dissipate
Bketchum5
Active member
Jun 17, 2018
38
edmond,OK
Can you take a picture of what "a lot" looks like? Could it be your SWCG?
I’ll post some pics but how would swcg effect it? I’m assuming air is coming from suction side, not discharge side.
May 3, 2020
11
Poway, CA
CircuPool Edge-40
I had a suction side air leak, and it drove me crazy seeing air bubbles in the returns. I ended up replacing the o-rings on the suction side Jandy 3 way valve and that cleared it up. I noticed if I turned the valve all the way to skimmer side or all the way to the cleaner port the bubbles got better or worse. A set of o-rings on Amazon is just a couple of bucks so I ended up swapping out all of mine and no issues since.
cowboycasey
5,805
Southern OK
if air is getting into your pump basket/lid you have 1 of the following..
1. water level is too low and you are pulling air into the skimmer, look into the skimmer and see if it is pulling air into it...
2. suction side leak.. do you have 2 skimmers? can you run just 1?
3. take the lid off, clean and lube the O ring and reinstall
Shirker
613
Athens, GA - USA
SWCG generates bubbles of hydrogen. When my pump is on low, can see the bubbles stream out about a dozen at a time. After running on low for a while and then going to higher, I get a bunch of bubbles at one time. Probably not your issue but trying to rule stuff out.
