Hi, I have an intex sand filter. When I try to bleed the air when the pump is on filter mode, the strainer basket starts to fill up with more air. Why?!
When I bleed the air with the pump off, the air bleeds out just fine. I have checked o rings, unions, water line is good. I have not seen anyone else explain this problem.
Shouldn’t I be able to bleed the air while the pump is running?
