I received a hot tub (2013 coyote laredo) with the purchase of my house and have finally got around to taking care of it. I had a local pool/spa guy come out and do a purge (he used some name-brand spa purge), drain, and fill. The water looked clear and great, but unfortunately the levels weren't right (pH always 8+) so I decided to figure it out on my own. After some playing with the chemistries, I gave up and figured I needed to start from scratch and do it myself to make sure it's right from the start (truth is, I just didn't know enough to get it right, but I started over anyways).
So yesterday I followed the decontamination procedure I found on another forum using ahh-some to purge and then high levels of bleach to kill everything. I didn't drain in between the purge and bleach parts since we are in a drought-restricted area, but felt like we got it good enough. There wasn't very much biofilm that came out (especially compared to some of the posts I've seen), which made me feel good about the initial work the local guy did. We filled it up, I spent all of last night reading the forum and trying to get the water balanced (I have very different water here than what I see from others), but I finally got everything balanced (pH: 7.6, TA: 50, CH: 200) and so I added in some bromine granules, MPS, and my floater with bromine tabs and went to bed.
I went out today (about 14 hours later) to check the bromine level (which was 20ppm, I definitely added too much MPS I guess) and I noticed a bit of dark green/black biofilm (same as what came out yesterday) built up in a couple places right above the water line. There wasn't a lot, just a bit around one jet and two lines each about 6 inches long. At this point, I'm not sure if I should be concerned or if this is normal following a good purge. Could I have awaken the biofilm beast and now I am getting it spreading around and growing on the tub? Or is this just some that got knocked loose and never got flushed out, but is harmless and dead? We never saw any trace of anything after the purge from the local pool guy, but then again, ahh-some works way better than anything he would have used. What do you guys usually see after a purge? Is there residual for the next day or two? We wiped it all off with bleach and will be monitoring it (and unfortunately staying out of the tub) until we figure out what to do.
Also, before anyone asks - yes, I'm using a Taylor kit (2106) for my testing.
