The grandkids are growing like weeds so the next pool will be deeper. 54" is the deepest I've seen, is it worth it over a 48 inch? Appreciate any thoughts/experiences on the subject. Thx!
...54" is the deepest I've seen, is it worth it over a 48 inch?
If you are going to dish out a deep end, you need a traditional hard wall AGP with a special expandable liner. Soft wall Intex style pools are not designed to be dished out.
Also if you want to dish out the center an oval pool more than likely won't work. Most oval pools have ties that run under the pool to join the two long walls.
Yes that's a problem with the newer buttress free designs. I've been looking at that too and there are instructions for cutting the straps, attaching them to a cement block and burying it as described here: PSC Ep. 50: Can I use an expandable liner with my oval pool? - INYOPools.com
Edit: Actually I misread your post slightly. I see you are talking about dishing out the center area. That would be a lot of straps to cut and I don't know if anyone has done that. Most do it on one end so have minimal straps to cut. I'd be afraid to cut ALL the straps although that's not based on any analysis or experience...maybe the solution linked above would allow it I don't know.
