After new VS pump installation - leak exposed?
southflorida427
97
Miami FL
I recently installed a new VS pump. I did my own plumbing, it was in and out, an easy job.
I'm losing water, for December in South Florida I don't recall evaporation to be an issue in past seasons.
I don't see any evident leaks on the new connections. Nor I see watermarks or any puddles near the pump area.
Is it possible that running the VS at low speeds is making an existing leak more evident? I see bubbles on the return only while at low speed, when I crank up the speed no bubbles are seen.
Suggestions? Ideas?
Thnx!
PoolGate
5,353
Damascus, MD
Jandy Aquapure 1400
Do you have a saltwater chlorine generator (SWG)? They produce bubbles of hydrogen that are evident when running at low speeds. You can do a leak test to see of you have a leak.
Reactions: southflorida427
southflorida427
97
Miami FL
I do have an SGW.
I will do the bucket test in the afternoon.
Thnx for the suggestions.
Jimrahbe
20,789
Bedford, TX
427,
No magic at all.. The SWCG produces small bubbles that you just do not see when using a single speed pump, due to the large amount of water flow..
