Have cleaned and dosed my 12,000 gallon pool for about 8 years now with good success, no algae outbreaks, happy swimmers and clear water. Until now with some algae in 107 heat, which is because I let the water go too long between changes and CYA levels have gotten astronomically high (when I read of people worried theirs is up to 165 and can't believe it got that high...that's nothing compared to a level you'll see in many an AZ pool). I have some repairs to make and a drain and refill to do, and now is a time to reconsider things. I've done all the following systems.
1. The TFP system.
2. Old FROG inline system (currently old and leaking and needs replaced)
3. Tricholor chlorine feeder system
4. Floaters in combo with liquid chlorine
The problem is with our vicious AZ sunshine and UV, chlorine just disappears like crazy from a shallower 6' pool from May-September. The east-coasters and northerners really have it very easy with chlorine, you can just add in reasonable amount of bleach with a safe CYA level and it will actually hold there. Southern AZ, not so much, especially from June-August. You have to use HUGE amount of chlorine bleach bottles. It's too much and I can't stand it after awhile. So I break and go to trichlor. Saltwater generators are probably the best solution, but out here lots of mixed reviews with our super hard water and other factors.
So for now, really do want to go back to a mineral based system, like FROG or Nature2 (and using an offline feeder, floater or liquid chlorine or combo thereof) and run at 0.5-1 ppm chlorine. When ran Frog when first moved in, was new to pool maintenance and ran the free chlorine still at 3 ppm so was changing those pacs too much. You can make your own with 1" tabs so the chlorine costs really isn't an issue. Nor did I see how low of chlorine level that the pool could safely and effectively get away with, and for how long. CYA does continue to build, though at a slower rate. I wouldn't mind doing a once a week bleach add in if had minerals helping. But 0.5 free chlorine is unsafe at high CYA levels and you're really relying a lot on the minerals at that point as the time grows and the water gets "older' from the last water change, so that part of the system is still a weak point to me with creeping CYA levels. Can't remember how long I was able to hold the range in the 50-150 ppm range before a water change would be needed.
Really just wondering if people have had much success in super hot, super sunny locations, shallower pool using a mineral system and running low chlorine levels? And if it helped delay drain and refill times, and were able to manage CYA levels effectively by using fewer tabs and some liquid chlorine (at a reasonable level of chlorine bottle usage.)
1. The TFP system.
