I noticed the water level in our pool was down and found the problem was water leaking from the bottom of the black rubber cap that sticks out of the top of the condenser (has a wire going into it which I believe is the thermostat sensor). It only leaks when the pool pump is on, doesn't matter if the heater is on or off. I've been doing my research and I think there may be a hole in the temp sense well (part # STK1113A). AquaCal tech support isn't open until Monday and they are probably just going to want to send someone out and since the heater is 18 years old I'd rather not pay for them to service it if this is something I can do myself. I can't remove the black rubber cap easily because there is a zip tie around it and I'm afraid to cut that off right now until I know what I'm doing. Does anyone know if this part is something I can easily replace and help me with instructions? And is there a way to bypass this in the meantime so I can run the pool pump and not lose water? Thanks! Ann
