I have a 6-port, low-profile Tsunami valve for pop-up in-floor cleaners in my pool. Inside is a gear-set that can be seen here (https://www.amazon.com/Manufacturing-540277-6-Port-Low-Parts/dp/B00HEAPGZ8).
After the impeller/gear (top right in the picture) wore out, I replaced the entire gear set in March of 2017. One cannot just buy the impeller gear and be done with it. No, you must be the entire set; about $100 at the local pool supply place--shop local!
The top impeller-gear appears to be worn out again, and curiously, another failure is occuring: the actual stainless steel shaft is wearing down in the middle where the impeller-gear spins! This, in turn, causes more wobbling of the impeller-gear, more noise, and basically seals its fate.
So how often do these gears need to be replaced? Seems like every 3 years is a bit much, especially since I run my VS pump at low speeds most of the time. Furthermore, I think the wearing-away of the SS shaft is crazy.
