We recently bought a home with a pool and I'm just getting started (I just ordered TF-100). What I need next is to figure out how many gallons my kidney-shaped pool is. Anyone have any advice to make that easy?
Sure (I was just having this conversation on another thread, btw)We recently bought a home with a pool and I'm just getting started (I just ordered TF-100). What I need next is to figure out how many gallons my kidney-shaped pool is. Anyone have any advice to make that easy?
pretty straight forward. Here's the calculation. Please substitute your actual measurements.Here's a couple pictures of it. I can do a better sketch/measurements later today when I'm at home.
Afterwards, we chemically measured the volume using chlorine. 19,000 came out to be spot on, so we should have just measured it chemically from the start and avoided all that work.
Nah, that's not really overboard.I went overboard too. Superimposed the shape from googlemaps satellite view onto an excel spreadsheet and used a formula to approximate the depth of each square cell within the shape. Then figure out the scale of the squares and calculate it all out.
I needed to figure out how much of the pool to drain for 50% water volume. Figured that out and upped my dork credentials all at once!
Why bother figuring out how much to drain the pool 50%. Why didn't you just drain it half way ???????I went overboard too. Superimposed the shape from googlemaps satellite view onto an excel spreadsheet and used a formula to approximate the depth of each square cell within the shape. Then figure out the scale of the squares and calculate it all out.
I thought you were going to tell us that you bought a 3D printer, and duplicated a 1:100 scale model of your pool, then measured the amount of water it took to fill the model.
it be jokeHalf way can be easier said than done if you have a free form pool with varying depths. Now if that was a joke then every joke needs a straight man. I've been told I lack a sense of humor so I'm just doing my part.
