Hi - new home with pool owner this year - thank you to everyone in the TFP community, have been trying to learn as much as possible by reading!
It is a weekend place, hoping to see if can implement TFP methods if only there on weekends. Currently have weekly pool service (lots of issues) but hope to change that next year.
Currently hoping for advice on a leak:
-Pool opening, water level was low approx 1 ft below skimmers
-Since then, have water loss - approx 3/4in per day. Did multiple 12hr overnight bucket tests with pump on and off (can't test through daytime when in use) - there's very minimal loss when pump is off, clearly losing more water when pump is on.
Does this mean the primary water loss should be assumed to be a pressure side leak?
-dug around the return line pipe into the gorund to the first 90 degree elbow and followed that line a little bit, did not see a leak and that soil was pretty dry. No wet spots seen
-have checked - no leak from backwash pipe, except for one particular episode - opened and cleaned multiport valve and seem sine.
The rectangular pool has a single suction side line leading to two skimmers on one side of the pool, and a single line leading to 4 returns on the opposite side.
-Pool co did a pressure test. They cut the skimmer return pipes, tested them and their conclusion was both sides are leaking. They may be right but just wasn't sure how reliable they are - twice their pressure rig set up wasn't seated well on the pipe and just blew right off and into the air while pressurizing, which did not inspire confidence. They also said they can't further locate leaks and they just recommended a big job, they'd dig up every single line in the ground to look for the leaks (includes dismantling pavers, patio all around pool). That definitely didn't sound quite right
Doesn't seem like main water loss is from within the pool, but have also tried to check, because the opening pool level was low:
-been told the main drain is dead, hasn't been used for the years and no one knows why. The valve at the equipment pad for that line is closed and taped shut. Just in case, I've dove and equipment off, unscrewed the main drain cover, did dye testing and no obvious leak seen. There was nothing in the bottom opening/(pot?) where in some online pics a hydrostatic valve would go - not sure if it's right but I put a screw in cap there that fit, and a winterizing plug in the side facing drain pipe. This made no difference it seems.
-liner is 3 years old. My own snorkeling/diving dye testing of skimmer plates, boxes, returns, single light, steps and any other suspicious site hasn't turned up anything obvious, maybe I'm just not experienced enough to detect anything.
From reading and researching seems like leak detection companies can use various tools/methods to listen with water/air pressure testing to much more accurately identify the site of leaks.
-Looking for any recommended leak detection services that will go to Suffolk/Eastern Long Island?
-in the mean time any advice for anything else to check or try?
Thanks!
Thanks!
