So I have my CYA at 40ish and my FC at the appropriate level. My TA is 210 and I want to get it down a bit. pH was 7.6 so I added nearly 1 Gallo of muriatic acid to drop the pH which worked like a charm. pH is now 7.0. So to aerate and raise pH is it as easy as pointing my returns up and letting the water run? I also have my slide running as well. Neighbors probably think I am weird. Anyways is that it? Now I wait? Just curious as to how long I should let it run? Or is it more just keeping an eye on it with an occasional test? Thanks very much!
