Has anyone gone to a Poolwerx store and had a water test which gives 2 results for Alkalinity? One for "Alkalinity" and one for "Adjusted Alkalinity"?
Occasionally I like to sanity check my test results against pool stores. Poolwerx has a digital meter system so I figured it would be less error-prone than Leslie's.
My tests show my TA around 70. Today, I got 80 from Leslie's, but this one from Poolwerx was odd:
Alkalinity: 66
Adjusted Alkalinity: 37
The guy said to ignore the first number, the second one is what's important -- yet he could not answer my question when I asked exactly *what* was being "adjusted" for? He just kept saying that's the number to use, and their suggestion was to add over 14lb of Alkalinity Up (to my 15k gallon pool) which, by my calculations, would raise my TA over 100 ppm!
He ALSO insisted that higher TA keeps pH from rising. I just kind of crossed my eyes and moved on with my day.
Does anyone know what that "adjusted" number is and why they're using it? I've never seen it mentioned here.
Alkalinity: 66
