greetings
i have completed slam and past all 3 tests however when i go into test mode it is telling me i have 0 ppm of salt, i used aquacheck test strips and read 2180 ppm i added 160 lbs of salt and 3 hours later i read 3240 ppm on new test strip. Test mode on DG220 still shows 0 ppm, i was going to go into maintenance mode on dg 220 and calibrate it to read 3240 ppm. is this the correct way to do it? as it stands my FC is drifting down since yesterday because purifier is not running because check system light is on. i cleaned cell yesterday and there was some flaking which is now gone. Tonight i will pull the sensor and look at blade and acid wash if needed. Is my thinking on calibrating sound right?
thank you in advance
