Specs:
17k gal, Vinyl, Liquid Chlorine / non-SWG. Based in NJ.
Chems:
FC 1.0
PH 7.1
TA 115
CYA 40
Question: Swung a little wide on TA when opening this year 2 days ago. Ph is low and TA is high. Should I up PH and hold TA as-is? Or drop TA, allow PH to drop with it, and then raise PH back up? I slam'd and chlorine is coming back down. Pool is 98% clear.
If I drop TA, I was thinking to do it with Muriatic Acid and then raise PH with Soda Ash. Was thinking to do all of that first, then increase chlorine to normal level going forward.
Chems:
FC 1.0
PH 7.1
TA 115
CYA 40
