I am getting some work done on the flagstone on my spa and I need to have the spa empty for 2 days. I can drain the spa but I would like to run the pool pump during this time. In the photo there is a yellow circle around the jandy actuator. If I could rotate that valve 180 degrees it would stop any water from going to the spa. I will also turn the blue circle to off so suction wont happen from the spa.
My question is, if I unscrew the actuator, can I put the handle back on (without the actuator) and manually rotate it to any position or will I have to open the valve housing up?
