Adding synthetic deck adjoining Kayak above ground pool/deck
Grendel2000
15
Maryland, USA
We own a 16x32 Kayak above ground pool with a deck extension (aluminum) of around 10 ft off of one short edge and about a 2' deck surrounding the other sides.
Overlooking the pool we currently have a screened in porch and also a 12 x 16 deck at a heigh approximately 6' above pool deck level. We are about to have it rebuilt with Trex synthetic decking . We'd like to "fill" the existing space with new Trex decking that's all at the same height as the existing pool deck creating a much larger, 2 tiered space that's uninterrupted (since going out a gate, down a flight of stairs, lowering a ladder, then going up more steps is kind of a pain [I know - first world problems...]).
My concern is thinking through the best solution to joining the new decking to the existing aluminum Kayak deck. I have a few issues:
- I need to ensure that we have a method to cover the pool properly over the winter. The existing cover anchors to clips that attach to the edge of the pool. I would need to either leave enough gap between the existing pool deck and the new Trex planks to allow getting the clips in position (an inch gap perhaps?) or find a new way to anchor the pool cover straps on that long edge of the pool that faces the new decking.
- If I did it that way is there a product made to span the gap to keep people from tripping, or things falling under the deck through the gap?
- Is there a better way to anchor the pool cover to a wood deck such that I could get rid of the clips for that side?
- Is there any advantage / disadvantage to making the new deck at the same level as the existing pool deck, vs. perhaps stepping it up 6-8 inches? I'm concerned that if we build at exactly the same height it might settle and be uneven over time. If we built it stepped up that would be a non-issue over time but it might not look as nice and could present a bit more of a trip hazard around the pool.
Thoughts (diagram below)?
Grendel,
I too think pics might help spark some ideas.
I like the idea of keeping the new decking the same level as the existing decking.
The first thing that pops into my mind about the cover connections, is to have small removable sections over the anchor points. In the summer they would be in place, maybe screwed down, and in the winter, they would be removed to allow the cover to be installed. This would eliminate the 1" gap.
Looks like a great project. :goodjob:
