Adding stabilizer if using tablets (day 1)?
Zone
Active member
May 25, 2020
36
Chicago
I am going to be filling up an intex 18x48 this weekend. First time owning a pool and been doing as much reading as possible.
This is a 3-4 month pool, and if the kids like it will use it again next year.
I was planning on using the floating chlorine tabs from Sams Club which I believe has stabilizer in it. On day 1 do I still put in stabilizer and chlorine or just start using the floating tablets?
My PH is pretty neutral already.
As for test kits I know the TFT-1000 is the top of the line, anything less expensive I can get by with?
Zone
Active member
May 25, 2020
36
Chicago
An 18' round by 48" deep pool has a lot of water.
You can treat it as a Seasonal pool, see Guide for Seasonal/Temporary Pools - Trouble Free Pool
You may have to drain it a couple times through out the summer. Up to you.
We still do not recommend using the trichlor tablets. The CYA will build too high in less than a month and your pool will not be in good chemistry shape.
Well draining it once would cost more than buying the proper test kit I guess!
So do you recommend treating it as a non-seasonal pool?
mknauss
33,861
Laughlin, NV
Again, up to you. If you get cloudy water or algae, you will drain. Did you read the Seasonal pool article I linked?
What is the volume of the pool?
Brett S
709
Orlando
It’s kind of a darned if you do, darned of you don’t sort of thing. If you don’t add some stabilizer right away then you’ll likely have problems keeping up your chlorine levels as the sun will burn it away pretty quickly. But as you’re probably aware, using tabs can cause your CYA levels to go too high and that will also cause problems with chlorination. So if you add extra stabilizer to start with then your CYA levels will just get too high even more quickly.
Zone
Active member
May 25, 2020
36
Chicago
So the best option would be to buy stabilizer...get it up to the right level...and then use liquid chlorine? I have a menards by me with plenty of 12% chlorine so that wont be an issue to get assuming it is the right product.
The pool is right under 7k gallons.
mknauss
33,861
Laughlin, NV
If you fill the pool before getting the kit, add 3 ppm FC worth of liquid chlorine at filling. Dissolve 30 ppm CYA using the sock method. Add 3 ppm FC worth of liquid chlorine every day until you get your test kit and can run all the tests.
Zone
Active member
May 25, 2020
36
Chicago
Thanks. So once I get it stabilized how often should I expect to put liquid chlorine in the pool? How long does it usually take to get stabilized?
mknauss
33,861
Laughlin, NV
You will add chlorine every day.
The CYA will dissolve in a day or less and then be able to be tested a couple days after.
mknauss
33,861
Laughlin, NV
Every day during swim season. You said you were taking the pool down this fall. Once your pool water temperature reaches 60F the chlorine demand slows way down.
If you are going to be away for a few days, use the tablets in a floater. But be sure to test and account for the CYA added.
Zone
Active member
May 25, 2020
36
Chicago
Got the pool up and running adding chlorine yesterday and CYA at night. The CYA dissolved via the sock method real quick just did some testing with the TF-100.
One quick question can I use the speed stirrer for the chlorine test not sure why one vial is labeled chlorine only using the speed stirrer vial can I do all the test?
FC - 5.0
CC- 0
TA - 140
CH - 175
CYA - 30
I am having trouble reading he PH I believe it is higher than the 8.2
kellyfair
2,925
Tampa, FL
Yep, you can use the Speed Stir for every test that requires stirring. Use the one tube for the chlorine test, the other tube for the rest. Rinse the Speed Stir “pill” between tests.
kellyfair
2,925
Tampa, FL
Some buy another pill so they don’t have to interrupt testing to rinse it. I should, just haven’t gotten around to it!
mknauss
33,861
Laughlin, NV
If your pH color match is 8 (or you might think higher), then input 8 for pH in Poolmath. Target 7.4. Be sure your TA test result is saved in Poolmath. Poolmath will tell you how much of the acid you tell it you will be using to add to the pool. Add the acid, at the return of the water into the pool. Circulate for 30 minutes and test TA and pH again.
Richard320
23,932
San Dimas, CA (LA County)
FC - 5.0
CC- 0
TA - 140
CH - 175
CYA - 30
I bought extra stirbars off ebay. They're 8X25mm. The CYA mixing bottle fits on the speedstir just fine. With the extra vial from the speedstir, I can run all the tests before I have to do any dishes.
Just dose the pool as if the pH is 8.2. If it's higher, you won't see the pH drop as far as you wanted and you just have to do it again.
