- Apr 10, 2018
- 5,189
- Plaster
- CircuPool RJ-45
My pool has an attached spa with an air vent that terminates at the pad. Bubbles are only generated by the pump when running at medium to high speeds.
What would happen if I attached a spa blower to the air vent at the pad?
Would I be able to generate bubbles without having to run the pump at higher speeds?
Do spa blowers allow air to flow through when off?
Any negative side effects?
I've got photos if they'll help.
