New here but took over maintenance of a family pool this year due to some unsavory water conditions all of last year.
I've been using this POS pump that I had laying around. Been running almost 4 weeks now.
POS Pump Def not enough time for promises of greatness. Used to use 2 of these in a PH up and PH Down containers for hydroponics set up. It never died and lasted the few months I had it set up, but wasn't subjected to the sun and outdoor conditions.
It pumps about ~3.3oz per minute for me, so I have it set on a few timers below. Ill run it a few times each day while the pump is running. It outputs from above the rail (24' AGP) where the return jet is.
Currently wired - Extension cord plugged into outdoor kasa smart plug -> Extension cord into Shelly 1PM Mini smart relay ->120V to 12V Mean well PSU -> POS Pump. Just in a water tight container.
The Shelly device was my fail safe if the Kasa doesn't shut off when I set it to. Right now, if the Shelly receives power, it is automatically on. I will set the Kasa to turn off usually anywhere from 4-10 minutes (Uses set time of day). Then I'll set the Shelly to auto turn off if still on after lets say 10 minutes. This way, if the kasa fails to turn off at it's specified time, the shelly will still turn off after the X number of minutes anyways. Only downfall is I will need to catch it during testing because if the Shelly doesn't turn off, it doesn't turn back on to reset the relay timer. I believe you can go deeper into coding to get the shelly to turn back on after XX minutes or add the schedule to the shelly too.
Been decently satisfied so far. I only go over there once during the week now. Usually Thursday to make sure the sweeping/robot was ran a bit during the week and to verify the FC and PH I was sent during the week is accurate to my expected testing. They still send me FC and PH tests daily/every other day that I track.
