If the pool calc is suggesting the FC should be 5, if I add more (liquid chlorine) than the suggested amount (as an example to 7-8) is that wasted chlorine? In other words, can I expect that to not be anymore effective than the level at 5?
I ask because in Texas, with the heat we have now, if I add enough to run it to 7-8, the next morning I am at 3 to 3.6ppm. Seems like losing 4-5 a day is a lot, but maybe not with this heat. Did an overnight test last week and it held in range overnight, will do another tonight.
Should I consider testing/adding more midday as well? Currently, add in the morning and then do maintenance/test/add 24 hours later (next morning).
