I want to add a low flow switch to my SWG system in case water flow stops and chlorine builds up.
The SWG has the pump plugged into it. There doesn't seem to be a way of adding a flow switch override to the SWG.
Is there a simple way of adding a flow switch controller before the SWG so that the SWG plugs into the controller.
I don't need or want to pay for anything fancy with Bluetooth or timer etc, just a controller for the flow switch which will in turn switch off the SWG/Pump.
Thanks
Thanks
