I have just finished my pool refurbishment and thanks to everyone on here it has been very smooth sailing so far keeping everything balanced.
I only have a single skimmer and no main drain so just one 2 inch suction line going back to the pump. I use a Hayward Poolvergnuegen*2 wheel suction cleaner and that requires adjusting the suction so that it travels the right speed and only climbs a certain distance up the walls (otherwise is sucks in air and makes a huge noise then the pump looses prime). Since I only have the single suction line, the only way I can do this is with a bypass leak valve thing that allows a certain amount of water into the vacuum hose after the vacuum, hence reducing the flow through the actual vacuum itself.
Anyway, long story short, it is a pain having to use this because it sucks in leaves, falls off the hose and is just a nuisance.
So I was debating adding one of these:
https://www.amazon.com/gp/aw/d/B004VU8O5I/ref=ox_sc_act_image_1?smid=ATVPDKIKX0DER&psc=1
above the waterline that I could plumb back to the pump with a 3 way valve to adjust the flow between the vacuum and skimmer. I have concrete coping around three side of the pool but am still in the process of finishing a wooden deck around the 4th side so I could build it in quite easily.
Would that be okay adding something like that above the waterline? Obviously it would always have air in it so everytime it turned the pump might loose prime briefly (but I could limit it to only about 16 inches of pipe above water level). Will it seal well enough for when the vacuum isn't plugged in?
Good idea or bad idea?
Sent from my Nexus 6P using Tapatalk
