I just realized i made a big boo boo. Fortunately i didnt add too much muriatic acid when i shocked my pool last night. But this morning my pool is cloudy. Is there anything i should do today?
You really need your own test kit.Thank god, ive been adding 2 gallons of regular clorox tho lately for my pool shock to my 17-18000 gallon pool bc my stabibilizer is a little on the high side, last i had it checked it was 80, but ive had to add a little water since then too
Test strips are less than worthless. We call them "guess strips"I still use my own strips, i did figure out how big of a rip off the stores are, i never buy anything there anymore except some equipment. I dont have my own kit tho, i just have them test it monthly and use my strips daily.
Thank god, ive been adding 2 gallons of regular clorox tho ...
The strips are more wrong than even close to right. Better to use an OTO only in maintenance mode than strips.Test strips might do if you are in maintenance mode. They are useless for clean up mode. Once you have algae you need to have one of the 2 recommended test kits to successfully get rid of it.
Cloudy water is usually a hint of growing algae.
Not only “free” they often pay the customer -offering a discount on items purchased-If/after you’ve allowed them to ‘test’ your water, and they can tell you what you ‘need’ to buy. ?You really need your own test kit.
Not much credence is given to pool store testing around here. While you would think that a "professional" would be the best, unfortunately in most cases it is quite the opposite. Between employees who blindly trust the word of chemical sales representatives and high school kids working in the pool store for the summer you end up with poor results from their testing. Plus, the results of their "testing" is used to convince you that you need to buy things. Why do you think that testing is free?
When I bought my house with a pool I went to several pool stores. They all told me my stabilizer was in the 80-100 range. When I saw the light and got my test kit I found my stabilizer was really around 250 (CYA tests above 100 are just a guess, not very specific contrary to what the pool store says). With a CYA of 250 I had to keep my chlorine level at around 20 just to keep algae away.
