- Jul 21, 2013
- 65,433
- Plaster
- Pentair Intellichlor IC-60
You can widen the expansion joint and run the wire in there for much of the way. Then you just need to cut the concrete from the expansion joint to the skimmer and cut a bit of concrete out by the skimmer so you can dig down and make the connection on the back of the skimmer.
What is the drain grate I boxed on orange for?
I night dig down by the yellow line and see how thick the concrete is and if you can dig under the slab to get to the skimmer.
