First of all, thank you all for existing and congregating here. I am 3 years into pool ownership and have learned most everything I know from Trouble Free Pool. I've been able to glean everything I've needed so far from previous posts/Pool School -- we are about to start a remodel (mini pebble, tile, coping, correcting electrical to the light), however, and I am having a heck of a time deciding if our plumbing needs to be touched in the process.
I'll include some pictures, but here are the facts: we currently have one skimmer and one return plumbed with PVC, and one main drain that is still plumbed directly to the pad via the original 1950s copper pipe. The pool is 12' x 32', and 8' at the deep end. About 20K gallons, if my maths are correct. We're in SoCal and don't winterize, 1.5hp VS pump... what am I forgetting? I'll include a picture of the equipment.
I am 99% decided on eliminating the main drain -- in addition to safety concerns, the fact is that I never utilize the main drain, and would be modifying (splitting and/or running through the skimmer) it in order for it to sit there unused.
That said, my question is now: do I add anything? The PB first suggested two new returns and a dedicated vacuum line, then just the vacuum line... but the more research I do, the more leery I become of losing suction power if it's split between the vacuum line and the skimmer (that is: if the skimmer won't function when the vacuum line is working, it seems I should just keep using the skimmer port for the vacuum, no?). The vacuum currently stays plugged into the skimmer 24/7, with a Gator AutoSkim in the hose. It runs for about 3 hours at "vacuuming" speed, and about 6 at low speed. I don't really feel the loss of the skimmer -- between the vacuum and the Gator, the top and bottom of the pool are nearly always spotless. Because the vacuum pulls water from the bottom, I am also very happy with circulation and turnover rates for moving chemicals, heat, etc.
THAT said, before I figured out this near-perfect setup, the single return and single skimmer left much to be desired. The skimmer picked up little, and the return definitely leaves some dead spots.
If I want to add anything anywhere except on the same side that the skimmer and single return are on now, that will of course involve breaking concrete. I just don't know if it's worth it. But I also know this is the time to do it.
So... I feel I'm a bit between a rock and a hard place. I have a system I am very happy with, and the pool has been this way for nearly 70 years(!). Minus the vacuum and Gator, however, the pool could admittedly have better circulation. I do have resale value and the like in mind, too.
I'd like to hear some, "If that were my pool, here's what I'd do..." input from some of you that are more experienced than I am. Would you add suction/returns? What would you add? Where would you put them? Am I over-thinking this and should leave well enough alone? Thank you in advance for hopefully pushing me out of this rut...
