Should I go ahead and add a second return in my 24ft pool while under construction. I know it will be so much easier to do now but I'm just not sure if it's needed. I have read threads about people doing this after they realize they have a circulation problem. I will be hard piping the lines so it wouldn't cost much more up front. I will also be able to cut the hole before installing the wall so I don't have to worry about keeping the shavings out of the pool.
I have a Hayward 1.5hp pump so I think I should be able to push the water pretty well.
Thanks
Thanks
